AVS › AVS Forum › Audio › Soundbars › Help connecting ct150
post #1 of 2
i didnt fully setup the bar yet i just tested it briefly the other day...is this placement of the bar its self ok?
or would it be better if i use mounting tape and elevate it above the cable box mounted to the top inside there
also im a little confused on what connection goes where if say i wanted to just hook up my popcorn hour media player to the ct150 what connections would go where without using the arc feature
post #2 of 2
Why start a new thread to ask the same question you asked in the main thread? It has been answered there (several times).
  Back to Forum: Soundbars
