AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Sub for a Polk system (Montior 70, Monitor 40, CS2)
post #1 of 12
I got a set of Monitor 70, Monitor 40 and a CS2 last weekend. Now I need a Sub.
Please suggest one under $1000. I would prefer wireless, but if there are distinct advantages to going wired i can do that.
My reciever is a Pioneer VSX 1021K
I'll use it for Movies and Music 50/50
post #2 of 12
VTF-15H. What's your room size?
post #3 of 12
Room size is 18x27
post #4 of 12
You might also look at the Outlaw Audio LFM-1 EX. You can purchase a wireless setup with it for a discount at the same time for $724 plus shipping. Also check the Outlaw Owners Thread for info on the Private Black Friday sale.
Here's a recent review on the EX:
http://www.audioholics.com/reviews/s...fm-1-ex-review
post #5 of 12
The review on audioholics suggests its good for a 5000 sqft space. Mine is a relatively small room and i do not listen at very high volumes either.
Some people suggested a relatively cheaper Polk PSW505 that was on sale with the speakers. whats the take on that.
post #6 of 12
No. It's 5,000 cubic feet. Your room is most be at least 4,000 cubic feet (if not more, depending on the ceiling height).
post #7 of 12
Not if you have $1000 money to spend on a subwoofer. Something from HSU with make you a lot happier
post #8 of 12
Thanks for the info. I will look out for the black friday sale as well.
post #9 of 12
If you are looking for sales, HSU has a the ULS-15 on sale for $999 plus $69 shipping.
http://www.hsuresearch.com/products/clearance.html
I would appreciate input from others, but this strikes me as a pretty righteous sub for $1000.
post #10 of 12
Hows the Klipsch Reference RW-12d presently on sale at newegg for 299
post #11 of 12
A step above the PSW505, but below the other subs mentioned so far. Best to get two.
post #12 of 12
http://www.avsforum.com/avs-vb/showthread.php?t=1303085
