Best Price for Panasonic AE4000
post #1 of 5
I'm in the market for one, the best price I can find is at https://www.audiogeneral.com
$1880 -$250 rebate from Panasonic = $1630.
Can anyone beat that?
post #2 of 5
That is a very good price. Keep in mind though their new projector can be found for less than that, so you should compare the two if you have not already.
post #3 of 5
What do you mean by "their new projector"? Are you comparing it to the ar-100? If you are....I did not think it was the replacement to the ae4000.
post #4 of 5
Pretty sure if you have a good light controlled room the 4000 would be the far better PJ
post #5 of 5
That's where mine will be going.
