Originally Posted by canuck
The price of the unit you linked to is the most tempting yet!! The only thing keeping me from ordering it is my concerns over it's compatibility with the HD66.
I strongly suspect that paperchaser's issues stem from the fact that the specs for the box that he is using state that it outputs 60hz 1080/720p. The box you linked to doesn't say anything about refresh rate or DLP link (although the 3d DLP setting seems encouraging) .
I know that the monoprice unit does in fact output at the required 120hz albeit only at 720p (which is no problem for me as that is the native resolution of the hd66)
My only question is whether or not the input signal for the monoprice unit has to be 120hz or can it upconvert(?) a 60hz signal which is what my wdtv is set to output. Hence my question about your blueray player's output settings.
yes, I think my issue is the 60hz vs the 120hz thats required to trigger the 3D link option on the HD66.
I woke up this morning thinking about it and ordered the Monoprice unit.
