AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Software and mic for quick sound sweeps
post #1 of 2
I use to use TruRta a while ago. I had to jump through hoops. Is there a simple way to use my laptop and check my speakers responses....
Nothing crazy, just to do some quick sweeps.
So that would be software and a mic
post #2 of 2
No you have to jump through hoops to setup an rta system.
Mic calibration and Soundcard issues are common problems for computer RTA systems. I assume that is the hoops you are talking about.
If you used trueRTA before it should be easier the 2nd time around.
You might check out room eq wizard. I didn't find it that hard to setup but there were still "hoops". monoprice might sell a few hundred dollar "turn key" setup.
Have Fun!
