"But being that they have about half the cone area of the 18, they don't need to have a motor of the same strength. Two drivers combined equals the same Sd as the td, so you can effectively add the bl."
that is an interesting way to think about it, but i'm not sure if that is right. the equations say its not.
"I forgot the specs, but isn't their cms under .5?"
cms is 183 um/N. qes which is probably what you meant is 0.69.
