AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp 2011 LC-70LE632U Owner's Thread
Official Sharp 2011 LC-70LE632U Owner's Thread - Page 45
post #1321 of 1516
Originally Posted by DaGamePimp View Post
Ok hockey fans (boy did this thread go OT ) try the new Game Mode 50 ftL / Bright room settings and cross your fingers.
Here... http://www.avsforum.com/avs-vb/showp...&postcount=308
Or all of my 632 CAL's are linked below in my sig.
Best of luck!
Jason
Awesome...I'll try these...though I'm GOING to the 'Yotes Game 5 tonight!!
Jason, how do these graph vs. the 40ftL Movie Mode settings I've been using? I'm thinking these may be good for daytime viewing in my very bright great room, and use the aforementioned Movie Mode settings for nighttime viewing...
Walt
post #1322 of 1516
Walt,
The movie mode CAL's are going to be more accurate, Game mode requires service menu calibration to get close to the accuracy of Movie mode (Chad B said the service menu is a bear to deal with so I am not tinkering around in there ).
The 50 ftL should do well in a very bright room as long as the settings cross over well to your set (obviously luck of the draw here, as always).
Jason
post #1323 of 1516
Walt,
Jason
Thanks, bud...will advise!
post #1324 of 1516
Best of luck!
Jason
I tried these settings last night for hockey and in my case it made the ice look greyish?....hard to explain, but so far the settings I posted above, while not perfect yet work the best for me so far....
post #1325 of 1516
Interesting...
I can tell you that more than likely the settings you posted will yield a very blue pushed brilliant white, which probably explains why you like the CAL for hockey.
The color temps suggested in that CAL range above 8000K and there does not appear to have been enough adjustment of blue to negate the drastic blue push that those color temps exhibit (at least based upon several 632's I have info on). All of the Pro level calibrations have been using Low color temp as it is the closest to 6500K out of the box, yet still high and blue pushed.
Now obviously none of these 'internet based' CAL's will be perfect set to set but there are some very consistent factors across all of them.
Jason
post #1326 of 1516
DaGamePimp...
Are all your calibrations for movie/TV watching? I ask because I notice that all of them have the Temp option set to Low. Which setting is best for videogames? I usually switch the Temp option to Mid-Low for gaming and Low for video content.
post #1327 of 1516
In each mode a Color Temp of LOW is the closest factory preset to 6500K, thus the starting point for proper calibrations.
Jason
post #1328 of 1516
Where can I find Jason's calibration settings?
post #1329 of 1516
Check the link in my sig (below).
Jason
post #1330 of 1516
Jason,
In my cable box should I choose ycc 444 or rgb in color space setting?
post #1331 of 1516
Well the 632's do not handle 4:4:4 properly but YCC would the correct choice unless the cable box has other errors that we are not aware of.
Jason
post #1332 of 1516
I have been using Jason's 40ftL Movie Mode settings for the past two weeks, and I like them (I'm using them across all inputs right now) - however, I'd like to try calibrating slightly more to my taste (for my panel), and was thinking of taking a run at my settings with the Disney WOW disc. Should I leave Jason's movie settings as my base and then tweak as necessary from there with the WOW disc, or set my TV to User Mode and start with a clean slate when running WOW? If I tried doing a visual calibration in User Mode this way, are there picture settings that will not be available? I saw a note from Jason earlier in the thread indicating that the Movie Mode setting had specific attributes that couldn't be found in other modes, making it the best one to try to adjust.
Thoughts?
post #1333 of 1516
Movie mode is the most capable from my testing regarding accuracy so try your own CAL in Movie mode with WOW and see how you like it. If you tweak my CAL's you'll probably be ok as long as no drastic changes are made, a click here and there, but if you have to shift color/tint by many clicks then you may as well just clear my settings and do your own as it probably means my CAL's are not working for your display.
Best of luck,
Jason
post #1334 of 1516
What is the general opinion about the latest firmware that Sharp released a week or two ago? I saw a note earlier in the thread that the firmware update may mess with the color setting,s but then it wasn't mentioned again. Was wondering if it is safe to update to this latest release...
Demian
post #1335 of 1516
I will be getting my 632 on Thursday. My question is which mount to get that will allow me to put it in the corner on the room. I have found a bunch that will hold the TV but I don't know how much it needs to extend from the wall to be able to get a 45° angle.
post #1336 of 1516
Hey all. I'm having a few problems with my 632U which I've only had a little over a month.
Anyway I contacted the company and they've offered to send me a LC70LE640U as a replacement.
Good move or bad move? Anyone have any experience comparing the two models?
Thank you!
post #1337 of 1516
Thank you!
I don't believe the 640 is a full array backlit.. so it's probably a bad move. Everything else between them is basically the same I believe.
post #1338 of 1516
Gotcha, I'll have to research that a little. I know the 640 adds the 4th pixel color which in reading through the threads seems debatable as to whether it's a pro or a con.
I guess it would make more sense for them to swap out the 632 with another 632.
post #1339 of 1516
You're talking about the quad pixel.. like the 732u has.. but I don't believe the 640 has that feature.
It's probably for the best anyway - near as I can tell it's a marketing gimmick that artificially changes the picture. Not something I'd want.
post #1340 of 1516
I researched it and the 640U does have the quad pixel and it is edge lit. Doesn't really sound like a step up from my 632U. Hopefully the company can swap it out with a 632, unfortunately they are tough to come by now
post #1341 of 1516
Walt,
Jason
For the Coyotes Game 1 on Sunday, I tried the 50 ftL Game settings. In my opinion, they were definitely "brighter", but the colors seemed to be somewhat oversaturated, blacks seemed a bit crushed, the picture didn't seem as "crisp" as the Movie settings (I had been using the 40 ftL Movie settings) and the audio was slightly out-of-sync. So I changed to the new 35 ftL Movie settings, and everything looked way better, despite the slightly darker picture. Overall, the Movie settings blow away the Game settings, IMO.
BTW, the audio was fine too...I was running the sound through my Sammy Bly-Ray HTIB, and have a slight delay set to account for the Movie mode. Going to Game screwed that up...
post #1342 of 1516
Sharp's own website lists it as a non quattron (sharpusa.com and sharp.ca).
I'm just wondering where you read that it was a quattron panel? I'm curious to know the truth here.
post #1343 of 1516
Demian
I'd like to know this as well. Anyone?
--Tom
post #1344 of 1516
--Tom
I installed it when it was released and havn't noticed any change in picture settings. Looks as good as before update.
Ed
post #1345 of 1516
You are correct; I must have read that wrongly on one of the many sites selling that model.
Anyway, what in everyone's opinion is an acceptable replacement model for the 632U? Sharp warranty service will be out to repair mine tomorrow, but the salesman said if I'm not happy with the result after that he'll replace it with a newer model.
post #1346 of 1516
You're not likely to convince them to give you anything better than the 640 I'd guess. If you're still not happy, either return the 632U if you can.. or take the 640. I doubt there is much of a real world difference between the full array (without local dimming) & the edge lit.
post #1347 of 1516
Are there any models better than the 640 I should attempt to squeeze from them instead? I'm not too familiar with the rest of the 70" line, especially the current models.
post #1348 of 1516
Doubtful they will do it (unless you add in a slight upgrade fee) but the 73x/74x series will give you some more calibration options (of course you also move into a quad pixel set and the benefits there are debatable).
Jason
post #1349 of 1516
Gotcha. Well, the first step is to see if they can get my 632 to 100%. Hopefully so, then no need for an upgrade.
post #1350 of 1516
Originally Posted by HowieDoin View Post
I found these settings on another site and seem to work the best for me....I input them with USER setting, but the author suggests STANDARD....anyways, hockey looked really good with this setting, as well as regular sitcoms etc....I have to say that this tv might haver the WORST factory settings ever...lol...anyways, give it a try and let me know if it improves anything for anyone...especially the hockey fans!....................................................... ................
Before Calibration - The TV LOOKED AWFUL!!!!! skin tones were way off and so on .
Settings Starting from top to bottom top written here Left to Right or Red first
wich for Hue would be +6 and work your way down
TINT IS VERY IMPORTANT TO LEAVE AT 0
HuE +6 0 -16 0 0 0 Skin tone fix
Saturation 0 -18 -4 -30 -13 -30 Rgb ballance
Value +10 0 -7 0 +20 0 Color Depth and Accuracy.
Each one of these changes affect 2 colors at a time thats why its hard to get them just right.Value affects
how strong Hue looks and so on .Saturation also affects how strong you set tint and Value .This is the closest
you will get without paying best buy 200bucks for calibration and you might not even notice any difference.
Color temp
You can use Med or Low Med user preference but set
0 0 0 +8 0 -10
Gama -1 / 0 looks better on shows like Icarly bc theres no shadow detail. Infact use 0 on those bright shows.
Backlight +2(turning backup up to high makes cablebox look to noisy) you need really high end HD to turn up to 16
Contrast 31 (32 makes faces wash out on sunlight eventhough calibration paterns say 32 is fine but its not)
Color +7 or your preference
brightness +1
sharpness +2
All you guys know to turn smooth motion off ,
noise reduction off, BUT you can set noise
reduction to low on your cable box or BluRays that have noticible noise. You can use Dynamic contrast as you wish bc it does help nexflix shows like 30rock wich tend to be on the greyish side .
These settings look great - Many thanks!
