Originally Posted by DaGamePimp
Yes game mode is tricky to get nailed down on the 632. Honestly these sets have an issue with all of the primaries in my opinion (RED being the biggest issue) so do not expect a perfect 6500k or D65 cal, it's a balancing act (it does not appear a perfect REC709 green can be obtained). You'll also discover that Y will shift as you adjust xy so this is not a 100% proper CMS implementation. My game mode 6500k cal on my 60LE632 is
You're welcome!
Yes leave DNR off and I do use Game mode for all sources except cable tv (Blu Ray/PC/PS3/Xbox360), do not expect perfect settings for your cable box, sadly television from cable to sat to OTA and from one channel to the next has source variables. I use Standard mode with cable tv as it seems to have the least amount of sync issues over most channels. I have just adjusted Standard mode by eye since you will never see a perfect NTSC signal across all channels (my cable tv source requires different contrast/brightness settings thus the different mode). As I said in the other thread... remember what NTSC stands for = Never The Same Color.
Jason
You're welcome!
Jason
Thanks for the info. Mind sharing your calibration plots?
I was actually able to get a very good cal using movie mode on my 732, all of my deltas for color are under 2 (with luminance difference of about 2 absolute) and greyscale is +/- 2 off 100. I am pretty much inside all of the boxes for the 709 spec. Problem is I don't know if I'll be able to give that up moving to game mode :P
Very happy with my purchase.
