AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Official JVC X30 / RS45 owner's thread!
Official JVC X30 / RS45 owner's thread! - Page 73
post #2161 of 4181
Doesn't seem to. Just when the 3-D is engaged.
post #2162 of 4181
Saw someone else mention a calibration thread..... I can't seem to find it
post #2163 of 4181
I'm wondering if the lamp fade has improved at all in this year's models.
If anyone already has a couple hundred hours or more on a RSxx, can you post some quick lumen numbers (new vs. now)?
The JVC lamp hour project thread is not showing any much over 30 hrs, so blasting a query here.
post #2164 of 4181
http://www.avsforum.com/avs-vb/showthread.php?t=1380763
post #2165 of 4181
You need a significant drop to see it with eye or to measure it with a cheap meter. The accuracy isn't tight enough, you'll have to wait until some people get to 300+ hours. I have a tiny tiny drop in brightness, but it's not visible by eye yet at 80 hours.
post #2166 of 4181
Originally Posted by Steve Smith View Post
My experience is that's it's not related to setup. The first RS45 I received had really bad vertical streaking which could easily be see from my seating position. It was sent back defective. The second one has very little with the exact same setup and is a huge improvement.
Attachment 232021
I just checked my RS45 and it has absolutely no vertical streaking. None. Each pixel is a pixel with a distinct line around it. Is your lens dirty ?
post #2167 of 4181
No, the lens was spotless. I don't thnk all 45's have this problem. How did you check for streaking? It shows up the most with bright text on a black background.
post #2168 of 4181
Originally Posted by elmerfudII View Post
I just checked my RS45 and it has absolutely no vertical streaking. None. Each pixel is a pixel. Is your lens dirty ?
I don't think lens is an issue. If it was, then it should be more "localized". The streaking actually happened on any bright text that had a dark background. The Oppo Logo to me is the worst, and then the "power-off warning" screen that Steve Posted earlier. Other that that, if you have a black background, bring up the Menu and all the text there showed streaking, and quite apparent even at 8-10 ft away... I actually had the same thing, and contacting my dealer... but I guess I would have to wait as he is out of stock already. BTW, I have a RS55.
post #2169 of 4181
Originally Posted by Gary Hudson View Post
Well, ten bucks worth of hardware from Lowes and I got my projector adapted to my older mount. It has a ball joint that locks, so all axis are adjusted at once.
I have the same thing and did the same thing ! Very frustrating to get set up perfectly.
I got it straight on the horizontal plane and just a tad tilted on vertical. I added +1 on keystone at the end of the night and the image is square. I may go back to reset the mount, but it is trial and error as tightening the ball joint isn't very precise. I may fix one axis and have trouble on the other.
Ditto !
What are people using for ceiling mounts on this thing ?
post #2170 of 4181
I don't think the lens hour meter is accurate on my RS45. It says its been running for 8 hours. There is no way its been running for 8 hours. More like 5. Anyone else notice this ?
post #2171 of 4181
Are you running on high? That will clock on more hours.
post #2172 of 4181
I would suggest that you try to get a replacement something seems very wrong. I have the 45 and have n streaking on the Oppo Logo or the menu. I don't even see it at one foot from the screen. When you first got your unit where was the lens shift? I am wondering if this problem is only with a small number of units.
post #2173 of 4181
Does anyone know of a good source to calibrate an RS45 with ? Like a DVD or BD of images ?
Is there a HOWTO guide somewhere for setting one up ? I was surprised by how little was in the manual.
BTW: I love my RS45 !
post #2174 of 4181
I was not aware of that. I was running on Normal. I am running with a color temp of 8500. Does that make a difference ?
BTW: I'm surprised at how loud the fan is on High.
I thought these things were supposed to be virtually silent. Maybe my mount adapter covers the vent too much. Its a plate that sits about 1/4" above it. I could put a spacer in between.
FWIW, my RS45 mounted to the plate with rubber isolators.
post #2175 of 4181
Yeah.. I think I need a replacement. When I first got mine, lens shift is way up.. i.e. it is projected to the ceiling (which makes me worry as I see nothing on my screen ).
post #2176 of 4181
Can you tell us your full Signal path ? i.e. Source type , output resolution , cabling , HDMI input , etc. ? I'm wondering if a true "1080p" Text is working and a non-1080p Text is giving the lines .
Scott...........
post #2177 of 4181
Yes.. Fan noise on HIGH is pretty loud. I don't think there is anything wrong with your mount, unless you are totally blocking it. On the other hand, LOW lamp is pretty quiet...
post #2178 of 4181
On mine, low lamp is dead silent as in can't hear it from 2 feet away, high lamp is a light whirring sound.
post #2179 of 4181
Scott...........
Unlikely.. The projector menu item by itself is also streaking... that means it is NOT source, HDMI, cabling issue.
post #2180 of 4181
No need to worry about the lens shift being way up. Mine was the same way as were many others. I don't have the streaking issue. How is your convergence?
post #2181 of 4181
If you want to calibrate, you need a calibration disc like DVEHD or AVSHD (Free).
If you want to go further, you need a meter and software as well. There is a "dummies for calibration" guide somewhere out there that describe it.
post #2182 of 4181
Convergence is OK... not enough that I need to mess around. And it is pretty sharp as well. It is also pretty bright (700/1100 on THX)... So, the only issue is the streaking..
post #2183 of 4181
I finally got my new RS45 ceiling mounted, and I've run into a bit of a problem. It's replacing an RS1, so when I got the new Chief plate, I simply put the RS45 in its place.
But it appears that the range of lens shift is more limited compared to the RS1. After much back and forth with shifting and zooming, I managed to get about 90% of my 106" screen filled, but that's as good as I can get. The throw is short: around 12 feet. The screen is fairly low.
I have an angled bracket attached to my slightly vaulted ceiling with large lag bolts right into a ceiling joist. A 14" or so post comes down from there and then the projector bracket. At the time I wanted to be 100% sure that it was solid, though I probably overdid it.
Anyway, it's around 10-12" left of the center of my screen (how do I figure that out anyway?). So, I'm thinking my only option is to re-install the ceiling mount to be centered with the screen. Would I be OK with toggle bolts into the drywall? I'm not much of a DIY person, so I'm not sure what the best solution is.
post #2184 of 4181
As far as I know, centering the image, i.e. moving it parallel to the screen, will not give you any increase in image size. I would verify that before you do the work of moving the mount.
post #2185 of 4181
Regarding the lens streaking some are experiencing...
Do any of you with this issue watch foreign movies with subtitles?
How noticable or annoying is it in the above scenario?
post #2186 of 4181
Toggle bolt weight capacities are not rated for ceilings, only walls. I definitely would not attempt this with something as heavy as the JVC projector.
you might have to open up that part of the ceiling and run a 2x4 cross brace or something similar to secure it properly.
post #2187 of 4181
i havent tried this but see it on some credits (at the beginning of movies, i dont really watch the ones at the end) if i look for it at ~9 ft. I havent watched anything with subtitles, but at that same distance I imagine it would be visible and annoying (again, mainly because I am looking for it - i actually doubt any guest would mention it at 9ft+ if they didnt know to look for it).
post #2188 of 4181
Clarify a some setup things:
- your screen size is 106" diagonal or horizontal measurement?
- what is your lens height?
- your 12ft throw distance is for sure from the lens front to the screen?
- a good method to verify lens offset is to get a tape and measure from a common side wall to the lens center, then the same thing for the screen middle. Offset is the diff.
As far as hanging from drywall, don't do it. If you have to hang it from a location without direct access to ceiling joists, then cut a rectangle piece of 3/4" plywood long enough to span the two closest joists and screw that to the ceiling (paint the plywood to match the ceiling or mount). Then attach your mount to the plywood.
post #2189 of 4181
But then we're assuming the EEPROM Menu was encoded as a 1080p Text ? I believe the AVSHD709 Disk was all recorded at 1080p . Like to see how a known 1080p Text is displayed . Could be something with the individual setup but best to rule out the obvious . Best if they had an external Pattern Generator.
Scott................
post #2190 of 4181
I can try the AVS disk later today. I see that as Oppo screen, so that should be 1080p as well. I have not try PC yet, had anyone try?
