Originally Posted by sanderdvd
I have some questions about the configuration settings of the RS45.
1. HDMI Input
I can selecact Standard (16-235), Enhanced (0-255) or Super White (16-255).
What is the setting that should be used when using a HTPC with:
- Blu-Ray content to play
- Media Player Classic Home Cinema
- madVR as output renderer (set to PC levels 0-255 as RGB output levels)
- LAV video filter (RGB set to 'untouched' in LAV video filter)
- NVIDIA GTX460 with default 1080p23 profile BUT with n vidia fix during installation (for further information about this fix check http://forums.nvidia.com/index.php?s...post&p=1328716)
2. Color Space
I can select YCbCr (4:4:4), YCbCr (4:2:2) or RGB. It seems that only RGB seems to show the correct colours. I thought Blu-Ray specification was 4:2:2?
1. HDMI Input
2. Color Space
Hi
I am running MPCHC with MadVR and LAV splitter + lav video decoder + ffdshow video decoder and audio decoder.
I had a lot of issues getting the whites not to clip amd blacks not to be grey but here is how it should be to preserve btb and prevent clipping.
PC
- madVR properties PClevels (0-255) or black will not be displayed properly (i know it is not "video correct" to send pc levels for video, but its the only way to not wash out blacks)
- Graphic card (Nvidia) -desktop colour settings - digital colour format = RGB
JVC
Inputsignal - HDMI = Super white (to prevent clipping whiter than white for movies and also IE whites get ****ed up with "standard ...totally overblown")
Input signal - colour space = auto (works excellent)
Picture adjust - advanced - colour space = standard (since videos are not recorded with a wide gamut)
Funny though - 2 places they name colour space - guess they just made a mistake
Settings checked with several test patterns - all checking out as they should.
Regards
Boogieman
) and how important 3d is to you since there are much better options for that which also have good 2d. I own a 45 and love it by the way for 2d, but I am pretty much completely turned off with the 3d at this point due to ghosting and flicker.
