AVS › AVS Forum › 3D Central › 3D Tech Talk › Help! to 3D or not 3D?
post #1 of 2
Please help if anyone can! I would really appreciate a straight forward answer to our problem.
We have a new Optivision 3D compatible projector.
Bought a Samsung 3D Blue-Ray/DVD player
The player nor the projector will play in 3D when directly connected. We get a message that we do not have 3D capablity when popping in a 3D movie or trying to watch On Demand. Have tried a new HDMI cable that specifies 3D on the package (8ft). and hooked up a digital optical cable from soundbar to DVDplayer, which is fine. Still no 3D! checked all the settings, The only thing I don't understand in the settings is "3D NR" (High,Med, or Low) we chose high. DO we need some kind of converter or transmitter??? Do we need a 3D AV receiver?? (other threads do not make it seem recommended) NO one at the stores seems to know anything about this stuff! What happened to the good old days of plug&play Optivision came with a really lame booklet, and website is not at all helpful either. It just doesn't seem like it should be so complicated
post #2 of 2
It's Optavision right?
You are going to need some help from the manufacturer here. There is nothing in their posted specs about their 3D support at all. They don't even list the HDMI features they support or don't support.
  Back to Forum: 3D Tech Talk
