Now that the high pitched ringing noise is gone, I wanted to put that aside and list some of the pros and cons of this set from my experience so far.
Pros:
Very high value proposition - Lot's of size and features for the money.
Very slim and light.
High contrast ratio (not top tier, but good)
Internet apps actually work well
3D is also good for passive (which I prefer)
Cons:
Glossy screen (reflection issues)
Picture quality quickly deteriorates for off axis viewing angles
A little bit of blooming or strobing in some situations (also depends on picture settings)
I'm using it in a bedroom for TV/Movie watching and playing video games. My primary light sources are torcheire lamps that are slightly behind the TV and well to it's sides, so the reflection issues are not terribly noticeable. On the other hand, I can't recommend it if you're going to have any bright lights directly reflecting off of it. I really wish that they had gone with a matte finish like their older sets.
Since I'm watching it directly in most cases the off angle viewing is not a killer, but it's much worse that I've seen on many other LCD panels. I don't have a lot of experience with LED lit models, so that might be something that goes with the territory. Then again I'm closer to it in the bedroom than I would be in a living room where the distance might help mitigate the off angle viewing issues somewhat.
Overall I would rate it a good value, but not a top tier set, or Vizio's best work.
Pros:
Cons:
