AVS › AVS Forum › Audio › Home Theater In A Box › Need help deciding on a HTiB (or receiver & speakers?)
post #1 of 3
I'm a complete noob at home theater/audio but ever since I bought my Samsung UN55D6300 a few months ago I've wanted to get a good surround sound system because the TV's speakers are horrible. I've learned a while ago that you should 'do it once and do it right' so I'd definitely like to get something decent but would like to keep it under $600, of course cheaper would be better.
My Den/TV room is long and narrow at 11'x20' and because of the layout of the room, the seating and couch are on the length of the room. The seating area is on the 20' wall and the TV is directly across on a 6' wall with a fireplace on it's left side (in the corner) and a big 10' opening to the kitchen on it's right side. It's a little bit of an awkward layout for a home theater as the 2 rear speakers would be next to you (on end tables) and a 7.1 system is definitely out of the question. I have a Sony BD player (could switch to my PS3) and Verizon Fios/Motorola HD box hooked up to the TV. I also use the TV to regularly stream internet radio.
I was looking at a few systems at my local Best Buy and PC Richards and realized that (as lame as it sounds) I'd also like a system that is aesthetically pleasing besides of course the best sounding. I originally thought that I liked the Sony HT-SS380 but it honestly looked like a cheesy cheap pos. I liked the look of the Samsung soundbars and home theater systems but I'm not sure if a soundbar is good enough as I figure if I have such a good TV and will be watching BD that I should be using a comparable audio system. It also seems that the Samsung home theater systems aren't the best bang for the buck...Am I wrong on that or should I look into one of their systems?
After researching on here I'm finding that I should lean towards a system with a dedicated receiver vs one that has a BD player/receiver...Which brings me to the Denon DHT-1312ba, Onkyo HTS7409 & S3400, and Yamaha YHT395BL, 595 & 695...These are all available at PC Richards where I can get a VERY good deal as I'm friendly with the manager
Out of these systems I'd obviously want the best, but I also want something that is going to be user friendly (ie I'm a noob). I know some of these come with auto calibrating mics/programming and such and some do not, does that make a big difference for a noob like myself?
Would I get a better system for the same $$$ if I purchased a receiver and speaker package separately? If so, can you guys make some recommendations?
FWIW, On the main page on the Onkyo website, they show a system with the speaker grills removed (HERE). Can that be done on all of the Onkyo systems?
post #2 of 3
I am a noob as well when it comes to home theater systems... however, I went with the Onkyo HT-S7409 because it has internet connectivity and includes streaming internet content like SiriusXM, and Pandora. Plus, it is going for $488 on Amazon.
So far I love it and it sounds great. I am going to change out the speaker wires however, as the system comes with 24 gauge (very thin) wire and 14 gauge wire is more appropriate to the 6 ohm /130 watt ratings for the speakers. It was easy to setup and works great. I cannot wait to have the new wires installed and watch a great movie in full surround.
If there is anyone out there with information on the HT-S7409 (reviews, recommendations, etc.) please let me know.
post #3 of 3
While I appreciate the deals some of these HTibs offer...the best advice I was given a couple years ago is this. Buy a reciever from a company known for electronics and buy speakers from a company known for speakers. Therefor, I would suggest the Denon BA system over anything that includes Onkyo speakers. Onkyo makes quality recievers, but not so much for speakers. Denon makes quality recievers and Boston Aucoustics has a long history of speaker manufacturing...
  Back to Forum: Home Theater In A Box
