Hello,
I've reviewed various threads here and elsewhere on a topic similar to this, but I haven't seen one that addresses my issue.
I am a Brighthouse Networks cable subscriber using a Samsung DVR HD Model SMT-H3270 box on my main living room TV which is a Mitsubishi 65 inch rear projection. This Mitsubishi does [u]not[u] have HDMI so I am using component cables between the Samsung box and the Mitsubishi TV.
We just bought a new Panasonic 46 inch plasma TV for our bedroom. We will be mounting the new Panasonic on the wall and directly on the other side of the wall is where the Samsung box is located. Hence, I was hoping to use my current Samsung box on both the Mitsubishi and the Pansonic TVs fully understanding that I will have to watch the same thing on both TVs at any given time (whether it be TV or DVR recorded programs).
The problem is that when I tested my idea before putting any holes in the wall, I couldn't get both TVs to work at the same time. Basically I connected the Samsung's HDMI output to the Panasonic's HDMI input (via an HDMI cable, obviously) and connected the Samsung's component cable and digital audio output to the Mitsubishi (which is how it always is connected btw). But as I said I can't get them to display at the same time. When the HDMI is connected to the Pansonic TV the Mitsubishi TV won't display. When the HDMI is removed from the Panasonic, the Mitsubishi will display again like normal.
My assumption is that the Samsung box doesn't allow you to use both the HDMI output and the component output at the same time. The only reason I'm not sure is because I tried the same thing with another TV but this time I used the HDMI for the Panasonic TV and used regular composite (yellow, red, white) on the second TV and I was able to get everything to display on both TVs at the same time. Again, I'm assuming here, but I was wondering if that method worked because the HDMI was outputting HD and the composite cables were outputting non-HD.
So, I guess my questions, or guidance I'm hoping to get from someone more experienced than myself, are:
(1) Can anyone confirm that a Samsung DVR HD Model SMT-H3270 cannot send an HD signal though the HDMI output and the Component output at the same time?
(2) Maybe more importantly, can someone think of any options that will allow me to use the Samsung DVR HD Model SMT-H3270 box on BOTH the Panasonic TV via HDMI and the Mitsubishi TV via component cables and the digital audio cable at the same time?
If both TVs had HDMI I saw some threads discussing a work about via an active or passive splitter but that isn't a fix for my situation since both TVs don't have HDMI - hence why the thread title said "with a twist."
And, I should mention that I understand that I can simply rent another HD box from Brighthouse for $8.00 per month - I may just do that, but I'm not sure our planned usage in terms of how often we'll watch "TV" on the bedroom Panasonic justifies another box if I can find a work around to allow me to use the Samsung DVR HD Model SMT-H3270 box for both TVs.
Thanks for any suggestions.
IMO this is probably to detour people people from using HDMI to a display while also recording from its component or even composite outputs.
MP does sell HDMI
