I have my Mitsubishi HC1500 projector attached to my PC via HDMI cable. I've experienced repeated crashing (blue screen) of the PC, even after a re-install of Windows. I took the PC to be serviced and they found nothing wrong with it.
While the PC was in the shop, I borrowed my wife's PC and hooked it up to the Mitsubishi HC1500. Guess what? It crashed too (for the first time ever).
Could it be that the Mitsubishi HC1500 is crashing these computers? One computer is an HP running Windows XP, the other a newer Dell running Windows 7, but both seem to crash when connected to the Mitsubishi HC1500.
The PC repairman said it was unlikely (but possible) that the HC1500 is the problem.
Has anyone else experienced this kind of problem?
Thanks in advance!
Thanks in advance!
