I'm happily using a 250+ on a MBP to record clear QAM, and want to be able to record two shows at a time. I understand the dual tuner HD Homerun is the supported way to go, but my router is nowhere near my TV (or cable feed) so I'm thinking of a second 250+. Elgato writes that this is an 'unsupported feature' because EyeTV can't select which tuner to use, but when I spoke with them they said EyeTV only supports one device, that they can give no advice on this topic, and that although they've heard that it can work, it may not be stable.
Any advice on how to do this, pitfalls, best chance for success, or process for installation? Use two similar tuners or different ones? Since I already have a 250+ do I need to run the Setup Asst?
I get it that this was discussed in the EyeTV Lounge, but all that is inaccessible, so help will be appreciated.
