Originally Posted by jim2100
Everyone is free to compare the data to whatever standard they like. Do you have any suggestions on what we should compare the data with?
In my opinion, if the chance of failure in 6 months or 600 hours turns out to be more than 10%, then JVC has a problem with the 2011-2012 projectors and lamps that JVC needs to fix. If it is more than 20%, then JVC has a major problem.
Again, in my opinion, the chance of such an early failure should be only a few percent or less for a product like this.
I think it would be great to have people with other projectors (Sony etc) and models also reporting the same type of data. This way you can track not only how your pj is doing but how all pjs are doing, which are best, worst, and what the median base line is and what is a reasonable baseline etc.
It also would result in more widespread participation and for a project like this to be effective you need lots of data.
Maybe try reaching out to AVS member "coderguy". He runs the calculator web site and I think is interested in tracking this data too.
