I had some time off for the past few days so I decided to play around with my subs. I have 2 Klipsch RW-12 Ds and two PL-200s. I was not using the PL-200s for a while so I decided to blend them into my system. I have the Klipsch subs up front and the PL-200s in the rear of the room. I use an SMS-1 to even out the bass. I put the mic in my main seating position and used the parametric equalizer to remove the reaks and bring up a dip in ther lower range. I have a good clean flat response from the back row where I sit but when I moved the mic to the front row of seats, there is a big peak around 23hz and some dips from the 40 to 60 hz range. I adjusted the phase on the Klipsch subs in the front and it helped a little with the dips but not that much. Plus the spike at 23hz is still there. If I adjust the phase on the Klipsch to high it messes up my response with the back row. I have done everything I can do with the controls on both subs and in the SMS-1. The only thing I have not done is move the subs out of there current positions. I know Velodyne has a 5 microphone kit to go with the SMS-1 but I don't want to invest in that if I don't need to. Is there anything I can do to get more balance so people sitting in the front row on movie night are getting the same amount of bass as the back row?
The room is about 2400 cu. ft.
Attachment 229275
my Klipschs up front
Attachment 229276
my PL-200s in the rear
Attachment 229277
my seating area
Attachment 229278
back row response
Attachment 229281
front row response
Attachment 229275
Attachment 229276
Attachment 229277
my seating area
Attachment 229278
back row response
Attachment 229281
front row response
