AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Acer K330 and Optoma 3D Xl Box
post #1 of 9
Short question: Does the Acer K330 work with Optoma 3D Xl Box?
My Acer K330 says on HDMI Input with connectet 3D Box "Input not supported"
And now????
post #2 of 9
Probably not, as the 3DXL won't work with the Viewsonic PLED-W500, which is basically the same projector as the Acer K330.
However, there is another 3D processor, the Viewsonic VP3D1, that does work with the Viewsonic PLED-W500, so it will probably work with the Acer K330 as well. Keep in mind this hasn't been verified.
post #3 of 9
Uhhhh.. This is not even a 3D projector right?
post #4 of 9
yes its a 3d pj(all the clones are) ,as far as I know they will only do 1024x768 ,caped there for some reason.
post #5 of 9
I pulled it's specs up. I seen no mention of 3D support at all.
But even if it is 3D? The light output is to low for 3D use.
post #6 of 9
http://www.projectorcentral.com/Acer-K330.htm
3D Projector: PC 3D Ready
Comments: The Acer K330 takes advantage of the latest technologies. When paired with a computer supporting 120Hz output and 3D software along with 3D glasses, the Acer K330 can project 3D content to give entertainment an incredible boost
post #7 of 9
There is no mention of it on Acer's site, nor Amazon's site for the projector.
If it took 3D at 720p 120hz then it should be working with the 3DXL. It must only take 3D at some other resolution / frame rate.
post #8 of 9
did anyone tried yet?
post #9 of 9
From above
"as far as I know they will only do 1024x768"
This will NOT work with the 3DXL, has to take 3D at 720p 120hz.
