post #1 of 1
I'm looking for some speaker stands for my advent h300's and h200's. The issue is I'm not finding much taller than 36". If I go with 36", the surrounds will be about half obscured by the couch back. They should be around 40"+ to clear the couch, and I'd prefer not to mount them on the walls or ceiling.
The floor is, I believe, berber style carpet with padding.
The front speakers would be fine with 30"-36", as that will keep them above the couch arm on the right side (no obstructions on the left).
Am I out of luck finding stands for these surrounds?
