AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Can my original XBOX 360 do 3D over component cables?
post #1 of 9
I have the original XBOX 360 with the 20GB hard drive and no HDMI output (I am using component cables). I have a 3D TV and want to try some 3D gaming.
I understand that for "real" 3D you need an HDMI connection. However I would think that I should be able to at least use SBS 3D from the XBOX 360 over component. Is this possible?
I downloaded the demo of Sonic Generations. It says I need a 3D TV to enable 3D mode when I try. I understand there is supposed to be an option under System Settings in the 360 DashBoard to tell the system that you have a 3D TV. But when I go under there I do not have the option where I can tell it that I have a 3D capable display. Is that option only listed when a HDMI connection is used?
post #2 of 9
Component Video can only do the old fake "Red" and "Green" glasses 3D. It's not possible to do today's 3D because there are a lot more frames for left and right eyes that Component Video cannot handle. Plus with the digital encryption requirement, it will never happen anyway.
One of the newer games that has the "Red/Green" glasses is the 1st Batman AA GOTY. The glasses come with the game.
post #3 of 9
"It's not possible to do today's 3D because there are a lot more frames for left and right eyes that Component Video cannot handle"
This is not a valid reason. Rendering a game with a 30fps cap fits well within the 60hz progressive limit of component video, using full frame video. Side-by-side, or interlaced 3D frames also entirely bypass this framerate limitation, as you can get 60fps inside of 60hz by displaying two rendered frames inside of each component video frame. Hell, you could run 60fps 3D video inside of 480i composite using side-by-side, if you wanted.
LovingDVD - 3D support on the 360 is on a per-game basis. Different games support different formats. There was a game on Xbox Live Arcade that contained a large variety of 3D options, but the name of it escapes me at the moment. It was something of a side-scrolling kung fu game. If I understand correctly, on the PS3 3D support is more of a system-wide thing, where games rely on a system software setting to enable 3D instead of needing to bring their own solution to the table.
post #4 of 9
Invincible Tiger, that's it. Go download the demo for Invincible Tiger.
http://marketplace.xbox.com/en-US/Pr...5-d80258410982
post #5 of 9
Some of us discovered that you can indeed use a pre-hdmi xbox 360 for 3D if you pass it through a 3D capable AVR that converts component to HDMI (I can confirm working on Denon 591 and others have it working with other AVR's).
Jason
post #6 of 9
Jason
Thanks everyone. I have an AVR that will take component In and give me HDMI out. In fact I'm using it like that already. But in Sonic Generations, just as an example, it tells me I must have a 3D TV when I try to enable 3D mode. And apparently there is no ET to tell the XBOX that I do have one because there is no such option shown in the System setting of the dashboard.
post #7 of 9
Again, 3D support on the 360 is on a per-game basis. You are fixated on a dashboard setting that has no effect on your desired end result. Go grab the game that I told you to grab earlier and see what happens.
post #8 of 9
COD Black Ops works through the AVR, as well as any other 3D capable game that I have tried (do not have Sonic Generations to try, sorry).
Jason
post #9 of 9
Yep, will do. I think the confusion came from the fact that the few games I happened to try only support frame packed.
  Back to Forum: Xbox Area
