Hello all, need your advice.
I have a Samsung PN59D6500, and I've been wanting to mount it. I received this mount as an early christmas present:
http://www.peerlessmounts.com/dyn/Pr...2/u/t/av/13966
I have metal studs. The mount says you must use their metal stud mounting kit, which are just toggle bolts, so I picked up the exact same size and type from home depot. The peerless mount needs to be mounted into drywall that is at least a half inch thick [check] and metal studs 26 gauge or heavier [unsure]
The wall I am mounting the tv to is not load bearing so I'd imagine its not 26 gauge (there is a planter shelf on top of the wall) but the wall seperates the living room from the garage, so its possible its reinforced with thicker gauged studs. Studs are 24" apart.
I've been reading mixed reviews regarding the security of mounting a tv to metal studs. First of all, my TV doesn't seem that heavy (67.5lbs according to samsung) , but I don't want to home home one day and my tv be sitting broken on my floor. Some people say the toggle bolts will hold just fine no matter the gauge, since there will be 2 toggles in each stud, and its a slim mount. Others say I need to take off the drywall and reinforce, or mount plywood to the wall and mount on top of that, which I don't think I'm interested in doing.
I figured I would direct my question to you fine folks, as I'm sure some of you have first hand knowledge and experience with this. What does everyone here think? I appreciate the feedback
