AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › BIGmouthinDC travels to Ohio to help build a Dennis Erskine designed space
BIGmouthinDC travels to Ohio to help build a Dennis Erskine designed space - Page 10
post #271 of 320
Originally Posted by Morph1c View Post
That's a lot of progress! - love the port-hole for the PJ. How many soft ice-cream cones gets BIG home?
Two slices of pizza ( 2 for $2.00 at Speedy's) and an extra strong 5 hour energy drink after loading up.
3 cups of coffee along the way
Leftover banana nut muffin from the hotel (Sara lee) That was what they considered a "Free Breakfast" and I typically grabbed one every morning even if I didn't plan to eat it. Two if they had chocolate.
3 meatball sliders and Utz chips from Sheetz at Breezeway.
No Ice cream this time.
After getting home I got take out for Dinner, Boston Chicken 1/2 chicken special for $7.99 with green beans, creamed spinach and corn bread.
post #272 of 320
Lol. U got a tummy ache with that mix?
post #273 of 320
I'm betting Big hasn't slept in 48 hrs after 3 coffees and a 5 hour energy drink.
post #274 of 320
Slept perfectly last night. Drinking my wake up call now.
post #275 of 320
Originally Posted by jimim View Post
Awesome! What kind of speakers?
B&W Matrix THX speakers
post #276 of 320
We should rename this the "BigGastroBuild" !
post #277 of 320
thanks for that. ur room is turning out really great. r u having it calibrated when done?
jim
post #278 of 320
jim
I haven't really decided yet.
post #279 of 320
Looking great! What is the acoustical treatment material? How high does it go off the floor? And why did you put fabric right next to the drywall? Seems like you could have saved on fabric by just covering thee posed fiberglass surface. Thx
post #280 of 320
Another awesome creation Jeff! Now get ready to come work on mine.
post #281 of 320
I'm currently taking reservations for May.
post #282 of 320
Combination of Linacoustic and 16 oz polyester batting (actually two layers of 8oz). The exact height of each is proprietary information of the designer of the room but has been discussed in at least a 100 threads in this forum. There is no fabric next to the drywall, Doing just the fiberglass area would have looked awkward given the column design and the differences in treatment specifications around the room. It was not the same. This plan covered all of the walls with fabric hiding the fact that there is a varied treatment strategy around the room.
post #283 of 320
Building the Riser
The original decking design was for three layers 3/4,1/2, 3/4 of OSB with Green Glue. One night standing at Lowe's we discovered that the only 3/4 they have was T&G which was going to be a hassle so bzbase got Dennis on his phone (the kind of service you get with the full design package) and he said three layers of 5/8 was going to be OK. So that is what we did
When you put the first layer of OSB on the joists, did you use Green Glue or Liquid Nails over the joists? What is recommended? Thanks
post #284 of 320
I would assume liquid nails on the joists...green in between the layers of OSB.
post #285 of 320
+1
post #286 of 320
I would recommend using PL Premium to glue the OSB to the joists instead of liquid nails. I don't know if liquid nails is recommended for use as a flooring adhesive or not.
post #287 of 320
The joist tops were covered with the paper insulation flanges from the insulation that per plan was suspended above the bottom communicating air gap. Glue would have been pointless so we screwed the crap out of it. Information on that aspect of the design should be directed to The DE group. I haven't bothered with glue on other projects just a pile of screws. Glue couldn't hurt.
post #288 of 320
Carpet was installed today. It is Stainmaster's Silver Lake from Lowes. Chairs from Roman are being delivered tomorrow and granite bartop hopefully this weekend.
post #289 of 320
I would assume the paper is just for protection against squeeks as thats what my framer told me to do when we built mine this past weekend. But who knows there could be some magic working in other ways.
post #290 of 320
Paper on top of the joist was to suspend the insulation not about the squeaks.
post #291 of 320
Well glad framer had me do it that way since Dennis just had it drawn on my plan. Framer said to me, "we can either put insulation flaps on joist and only glue the tongue/joints for decking, or we can staple insulation between joist and glue everywhere".
I chose to put flange on top of joist because framer said it would help with squeeks more than glue would.vIn any case I guess we got lucky and did it the correct way!
post #292 of 320
Sweet! I like the look of the rear wall with your 'projection booth', that came out very nice.
That orange cord is for a massive butt-kicker, right?
post #293 of 320
Very nice! Fun being near the end, isn't it?
post #294 of 320
Yes, but I still have a fairly large punchlist. I knocked out a few items over the weekend. I hauled the chairs down to the theater and built them. Then, I hauled the granite countertop down and set it in place. I think the college kid who helped carry it laughed his butt off about the # of breaks I needed. Here are some new pics.
post #295 of 320
Chicago has the best Pizza. Geppettos Pizza in Oak Park (close west suburb of Chicagoland). Their stuffied pies are the best!!
I keep hearing this but have never had good food from them! I live in Oak Park about 8 blocks from this place!
post #296 of 320
I love your granite bar in the back. I wanted to do exactly that myself but my theater depth request was denied by the wife. Looking good!
post #297 of 320
Tell me how you made the columns?
post #298 of 320
I didn't get any of that detail in my plans. What level plans were you working from? Does he have dimensions showing where the speakers and acoustic treatments should go? Mine are drawn on a 2D wall, but plans don't say where exactly they should go. Same for all the woodwork and the ceiling. Tim mentioned CAD & blueprints in his build thread... does he have anything that resembles blueprints? I have a collection of PDF's that look like they were created with Visio. I'm not sure I have enough detail to build the room. How did you treat the front wall? Do you normally have to figure all this stuff out for DE designed spaces?
post #299 of 320
All the plans were 2d, From what I recall nearly identical to yours. The details for the riser were different on my current project as the instructions were to fill the joist cavity not leave an air gap.
Edited by BIGmouthinDC - 12/2/12 at 4:39am
post #300 of 320
Print your plans full size and you can get dimensions that are missing using an architectural scaled ruler.
On the wood work, all the plans I've seen show the general shape and location of the finishing details but it is up to the owner to pick out final molding profiles etc. The ceiling plans are probably the most lacking as there are just a bunch of lines depicting the coffered ceiling general shape, Building from that is going to take some research and planning.
