AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › BIGmouthinDC travels to Ohio to help build a Dennis Erskine designed space
BIGmouthinDC travels to Ohio to help build a Dennis Erskine designed space - Page 11
post #301 of 320
So were the plans used for this room the "Room Layout Plan Set" or something more?
post #302 of 320
The plans were several thousand and A few years old when I started this project. They pre-dated the basic layout service.
post #303 of 320
post #304 of 320
post #305 of 320
Not sure the mobile version and I are going to get along
post #306 of 320
Yup. I'm not a big fan of the mobile version either. I have had issues with responses not loading, obviously you have had the opposite problem. biggrin.gif
RTROSE
post #307 of 320
+2
Not a fan of the mobile version. I can't get it to load threads at my last viewed post. I switched back to the desktop version on my mobile devices.
post #308 of 320
I don't like the mobile app either. It never works, always loading.
post #309 of 320
Big,
How were the columns made?
post #310 of 320
I made the tops and bottoms in my shop and then mated them with Fluted Columns purchased locally.
post #311 of 320
Thanks! I think I may do something like that for mine since they're such a low profile. It looks like you just routed the bottoms, and the tops are just molding?
post #312 of 320
Yes. but they were two layers of 1/2 MDF to start so that they would be thicker than the 3/4 inch fluting.
post #313 of 320
Great looking build! I live on the west side of Cleveland, so sorry I missed seeing the thread in time to stop by and help out.
Dave
post #314 of 320
Jeff,
Do you recall where you purchased the trim molding? I want to replicate them in the Theater Lobby.
Thanks!!
post #315 of 320
The only two spots we shopped in your town were Lowe's and Home Depot. Since Lowe's was closer I would check there first. I seem to remember we mixed and matched moldings from the two locations the day we were picking out the moldings so it really could be either location.
post #316 of 320
I'm refering to the tops and bottoms of the fluted columns. If I remember correctly, you built them in DC and brought them with you.
post #317 of 320
Two layers of MDF, I don't remember if it was 1/2 and 3/4 or two layers of 1/2. You can get easy to handle 1/2 pieces at HD you don't have to buy a 4x8 sheet. On the 3/4 you can grab a pre-cut shelf board.
The top detail is a molding called base cap, upside down
The bottom is 1/2 round.
I would have bought all at HD/Lowes. as that is the nearest locally.
Edited by BIGmouthinDC - 5/3/13 at 6:04pm
post #318 of 320
Thanks!!
post #319 of 320
Hi Big, any chance you can describe the bar build, I'm thinking of something similar in my room and interested how you constructed it and determined the height etc
post #320 of 320
two numbers I never forget are 36 and 42. Counters and Bartop heights.
Look at these pictures and if you have any more questions on bar construction let me know.
The ends were three layers of material rather than framed because I was conserving space for seating.
http://www.avsforum.com/t/1377216/bigmouthindc-travels-to-ohio-to-help-build-a-dennis-erskine-designed-space/240_40#post_21793348
