*Be cautious and very mindful when making adjustments.
I played around with it a little more and you can skew it up easily.
I was aligning the left side and it looked good but then when I looked at the right side, the red panel was crooked. Like a full pixel to high on the right side only and at angle.
I had to restore back to default and start over.
When you are adjusting the panels at specific coordinates, it's like tapping a piece of glass. If you tap down just on the top left, it moves the entire panel down on the left as a whole but the right side corner stays in place.
So the right will now require adjustment.
*See attached picture example of what happens.
I've found sticking to the center coordinates to make panel adjustment was the safest without skewing one of the panels to be aligned crooked.
I basically leave all 4 corner adjustments at default.
Then the last step of the alignment allows you to select specific coordinates and make adjustments. I select coordinates near the center and make adjustments.
*I also found that when ceiling mounted, it seems the direction of adjustment is reversed.
) to hear it.
