I have a weird problem that hopefully has a solution. I like to capture game footage from PC, Xbox360 and PS3 and then send it off to youtube. Right now I use a hauppauge colossus pvr using component cables and it works for everything but I'm either recording at 720p60 or 1080i neither of which easily makes it to youtube which seems to like 720p30 best, well 29.975. So I need to do a lot of re-encoding through Sony Vegas which takes time even on my Intel 2600k machine. Is there any scaler that can take in 720p60, 1080i, 1080p and make it all 720p30? Even worse i'm not sure if the colossus can even accept that format it says "input format determines the recorded format." so i'm hoping if I can some how feed it 720p30 it'll record that. Maybe I need to look into a different capture card? Not sure but I figured I would start here.
Thanks for looking.
Thanks for looking.
