AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › TC-P55ST30 serious blur gaming issues
post #1 of 8
I just bought my first plasma (p55ST30) and expected an improved picture quality, smoothness, and input lag over my older Sony xbr8 46 inch lcd.
Instead I got a horrible choppy (blurry) picture 9as opposed to smoothly flowing picture), after 30 minutes of PS3 gaming I got a headache (no kidding).
The sony was really flawless compared to this plasma, no choppiness whatsoever in any game. I wanted to improve more on my lag input with this TV but I got this choppiness instead.
This was on the game mode on this Panasonic TV.
I am very disappointed and before returning this TV i want to make sure I research and give every opportunity for this TV to stay on my wall.
Any ideas folks?
thanks
post #2 of 8
make sure that all the options are off like motion smoother and other stuff are to..
i have a 50 inch st30 and i get no blurryness. its smooth what kind of cables are you useing i also have a ps3 and make sure that you have 720 and 1080p checked off in the xmb in the ps3 i hope this helps,,
post #3 of 8
i have the motion smoother off on the PS3
i am using an HDMI cable, hopping to try the video component cable today and see if that helps.
the game that I am having blurriness trouble most is MAG, its an THX game, do you think that plays a role? but then I dont think the Sony xbr8 was THX certified
post #4 of 8
mag can be the problem. i play all the cods and have no trouble. what other games are giveing you trouble..THX certified only means that when u play a blu-ray it looks like the moive theather. my st30 is not THX certified.. but use game mode
post #5 of 8
ok, I think you're right. I played black ops (COD game) and it was great. I played Socom3 (made by Zipper that makes MAG too) and choppiness was all over the place.
I dont know what the deal with Zipper games I know Zipper is shutting down soon, so I am not sure if they have an answer for me
I am testing resistance 3 soon.
post #6 of 8
ok so Resistance 3 is also blurry. I think this TV can only plays 1080p games such as COD good. Everything else is blurry.
I am wondering if there is a magical setting I could change to fix this.
As of now I miss my Sony
post #7 of 8
The COD games don't even run at 720p. There are very few games that are natively 1080p. Almost all are upscaled.
I say swap the tv out for a new one and see if anything changes. Sounds like a very strange problem. I have a two year old G10 and have never experienced anything like that. Most others would probably agree.
post #8 of 8
yeah i would swap it like syed said the tv should not be doing this at all
