I think I may be a few steps behind you folks, but if you're trying to remap the RGB stimulus values so that...
My guess is that can probably be done this way...
(The gamma values shown in the plot in Post #25 are γ sRGB Rev. Trans. / γ Display for 0% to 100% Stimulus on a flat 2.22 display.)
To see if this works, I computed the new (ie remapped) stimulus values for a flat 2.22 display using the Stim In -> Stim Out equation above. And calculated the relative luminance of the new stimulus values to see if they match the sRGB Reverse Transform... and they were identical.
| % Stimulus In | Gamma Correction (γ sRGB Reverse Transform / 2.2222....) |
% Stimulus Out | Rel. Lum. of Stim Out on 2.22 Display (Stim Out ^ 2.2222...) |
| 10% | .8996 | 12.60% | .0100 |
| 20% | .9529 | 21.57% | .0331 |
| 30% | .9770 | 30.84% | .0732 |
| 40% | .9913 | 40.32% | .1329 |
| 50% | 1.0008 | 49.97% | .2140 |
| 60% | 1.0078 | 59.76% | .3185 |
| 70% | 1.0131 | 69.67% | .4480 |
| 80% | 1.0173 | 79.69% | .6038 |
| 90% | 1.0208 | 89.80% | .7874 |
Relative luminance values for the sRGB Reverse Transform from the table in post #5 for comparison:
| % Stimulus | Rel. Lum. of sRGB Reverse Transform | γ sRGB Reverse Transform |
| 10% | .0100 | 1.999 |
| 20% | .0331 | 2.118 |
| 30% | .0732 | 2.171 |
| 40% | .1329 | 2.203 |
| 50% (mid-gray) | .2140 | 2.224 |
| 60% | .3185 | 2.239 |
| 70% | .4480 | 2.251 |
| 80% | .6038 | 2.261 |
| 90% | .7874 | 2.268 |
Small reminder, the γ in equations, tables and graphs above refers to gamma, not luminance.
Edited by ADU - 2/2/13 at 1:58pm
Is this before or after sRGB calibration btw?
