I am arranging the speaker placement of my 7.1 system and have a couple of questions in regard of the placement of surround back speakers:
1) The manual of my Denon AVR-988 (mostly equivalent of AVR-2808CI spec-wise) recommends 60 degrees whereas Dolby recommends 135 to 150 degrees for the placement of rear surround speakers.
Since the difference seems not marginal, I would like to hear your take on this issue.
2) The distance between me and the rear surrounds is going to be too short because, due to the size of my TV, I can move forward my couch only up to 50 centimeters/20 inches, and generally only when watching content that does not fill the entire screen. When I move forward my couch as such, the gap between the couch and the wall barely accommodates my rear surround speakers.
According to the below article, “one requirement for 7.1-channel surround is sufficient space behind your couch and listening area—at least 5 feet or more. If your couch is jammed up against the rear wall or you have a comparatively small room of less than about 2,100 cu. ft. (length x width x height), the addition of two rear surround speakers will not likely add significant improvements in envelopment, especially if you are already using Axiom’s QS8 or QS4 “multi-polar” surround speakers.” I should note that although I do not have such space, my room is large and my speakers are direct radiating.
http://www.audioholics.com/education...surround-sound
Under these conditions, do you think that it would be better not to use rear surrounds at all?
If you don’t think so, or assuming that I would want to rear surrounds nonetheless, would your answer to the first question be changed?
In all 7.1 diagrams I have seen so far, the rear surrounds are placed behind the most left and right of a 3 to 4 seater-couch. Perhaps I can place them not behind my sofa in a way that my side surrounds and rear surrounds are aligned??
3) If I lean my sofa against the wall, then would it be extremely implausible to use 7.1 where the angle between me and the rear surrounds would be 90 and the side surrounds will be a tad in front of and facing towards me?
Thank you!
PS. I will use all speakers at ear level.
Thank you!
