Panasonic DMR-EH50, bought in fall 2005. Worked fine until about 6 months ago when I noticed one day it would not respond to remote control at all. I checked to make sure the remote codes were OK, the remote is fine as I can control the TV.
I was able to play content using the buttons on the main unit. I tried a lot of things and at one point I made the mistake to reset the main unit (I think I pressed Power and STOP for 5 seconds). Anyway, after I reset the unit, the unit comes back on and goes to the SETUP SCREEN! It tells me to press ENTER to continue. The unit will not respond to remote at all. There is no "ENTER" button on the main unit. I tried everything, another reset, CH UP and CH DOWN (I believe this restores the factory settings), nothing.
So now when unit powers up, it does a "HELLO" then a "SELF CHECK" and goes to Ch1 and SETUP SCREEN.
I opened the unit, found a Lithium 2450 battery, was 2.95V, replaced that with a fresh cell (3.25V). I saw people complaining about 2 bad capacitors on the power supply board. I check mine, they are fine. The hard Drive gets enough juice. It's like the IR sensor is bad or something.
Any idea on what else to troubleshoot next? I have time and patience to fool around with it, I am not willing to spend $130 to send it to that company in IL to get it fixed, but would be nice to use it to record some SD content.
Thanks folks
Thanks folks
