AVS › AVS Forum › Audio › Speakers › Can you recommend a center channel for >$200 that would go well with my setup?
post #1 of 14
I have:
  • Elemental designs sub
  • 4 (old) Paradigm Titans that i'm using as surrounds
  • 2 (newish) The Speaker Company P6-Pr that i'm using as front right and left (should i move these to be surrounds and use the paradigms up front?
  • and a denon avr 3808ci
I have been using a Paradigm cc-150 but both speakers in it blew and i think i might as well replace as opposed to repair.
I have a budget of around $200. Should i go with another elemental designs product? Someone has some Paradigm cc90 bookshelfs and a center channel for sale on my local craigslist which is tempting
post #2 of 14
How the heck did you blow the original center?
post #3 of 14
I'm not really sure... I think i was streaming a Phish concert on a new years eve. Excuse my lack of correct terms here but the foam/rubber ring around the speaker has separated from the plasticy part of the speaker.
post #4 of 14
If so, your thread title should read: "Can you recommend a center channel for <</font>$200 that would go well with my setup?"
post #5 of 14
Thanks for catching that.
post #6 of 14
would that paradigm cinemea cc be a good match? The craigslist seller will sell the two bookshelves (cinema 90s) and center channel for $70...seems like a killer deal.
otherwise HarmanAudio.com has Infinity CC225 on clearance for $212
post #7 of 14
Unless it will be a hassle to remove them from their installation, why not try three of the Titans in front right now? It would be a perfect timbre match.
post #8 of 14
I guess i never thought of that. Does it matter much that the titans i have are from the late 1990's? I'd have to replace my current center with a new Titan, or throw a new titan as a side/rear
post #9 of 14
You have nothing to lose by trying. If they sound good, it doesn't matter how old they are. I just sold a Paradigm Phantom v1 pair a few weeks ago that I have had for years. They still sounded great.
If it does sound good, then why not run 5.1 until you can save up for a nice set of matching L/R/C that would be a good upgrade to your system?
post #10 of 14
What would be a good upgrade to my paradigms? I dont have a need or desire to go to crazy on a home theater but I don't mind spending a couple hundred per speaker. i was thinking maybe three of these elemental designs... Does $200 buy a "decent" speaker?
http://www.edesignaudio.com/product_...roducts_id=967
post #11 of 14
I wouldn't recommend Elemental Designs to anyone. There have too many discussions about customer service issues on AVS, such as this one: http://avsforum.com/avs-vb/showthrea...ight=elemental
But that's up to you.
post #12 of 14
any suggestions?
post #13 of 14
I have not heard those Paradigm Titans. Which version number are they? Maybe someone would have an idea then.
As far as $600 for L/R/C, the HSU HB-1 and HC-1 are popular.
For a little bit more, a lot of people like the Energy RC series, on discount: RC-10 and RC-LCR.
The Ascend Acoustics CBM-170 SE and CMT-340 SE are also often recommended on AVS (I think there is a sale price if you click the Thanksgiving Day Sale link).
Maybe someone else can offer additional speaker suggestions in that budget range.
post #14 of 14
Thank you for the links. Much appreciated. I'm not sure the version number. I looked at the tag on them and it doesn't say anything. They're literally from 1998 or 1999. I bought them at the same time as my center channel, which is a Paradigm CC-150 if that helps.
The speakers seem fine but i realize it's probably time to upgrade...
  Back to Forum: Speakers
