AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › HDMI splitter and noise
post #1 of 2
I'm looking to split the HDMI out on my computer and divert to two receivers in different rooms. I'm concerned about noise more specifically in the audio. I've read many reviews on amazon complaining of unacceptable levels of noise. Can you guys recommend any splitters from personal experience, 3D is not a concern.
post #2 of 2
Exactly what type of noise did you hear about and where?
Remember HDMI sends 1s and 0s. If this "noise" is anything but dropouts, then you're looking in the wrong place. The audio 1s and 0s should not be being changed by the splitter. If you're worred about jitter - that has to do with the stability of the clock signal but shouldn't be a concern either (if it is see DenonLink 4).
