AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *Official* Popcorn Hour A-300 / C-300 Thread
*Official* Popcorn Hour A-300 / C-300 Thread - Page 7
post #181 of 377
I didn't notice this before, but I'm getting occasional frame skips on my Blu-ray rips (in MKV format). Doesn't happen with my Mede8er MED450X2 using the same settings. My PCH A-300 is set to 1080p/60 with NTSC/PAL/24. My receiver is set to 'through' for the video. I have the Optoma HD33 projector.
With my PCH, I even tried setting to Auto for the video, disabling NTSC/PAL/24, but still getting frame skips every few minutes, sometimes not for 10-15 minutes, then again. Never noticed anything like this when I had the A-210. Any ideas?
post #182 of 377
network on DAS?
post #183 of 377
^Have you tried setting Video Output to 1080P/24Hz mode?
post #184 of 377
What is DAS? I use Windows Home Server. LVS, when you say setting Video Output to 1080P/24Hz mode, do you mean on PCH or receiver (I have an Onkyo TX-NR609). I've tried both and also one but not the other.
post #185 of 377
I was referring to Video Output setting on PCH.
post #186 of 377
Direct Attached Storage. Otherwise I would look to network issues.
post #187 of 377
I'll try a couple of those movies via attached USB and see what happens. There aren't any known network issues w/the A-300 are there? Especially as my Boxee Box and Mede8er play over network just fine. Will try NFS as well.
post #188 of 377
MKV is decoded in software and is processor intensive. That's why I rip to M2TS DAS. Never any playback issues.
post #189 of 377
Do you mean stutters? or something like a slight judder. the time it takes doesnt make it sound like a frame rate problem, as you would notice right away.
post #190 of 377
Judder every few minutes. Happened with my full BD rip (MKV) of 'The Girl with the Dragon Tattoo' (US version) last night.
post #191 of 377
Are you sure it is not just you twitching and taking it for movie judder???
post #192 of 377
Info is up on the blog now and the main site has been changed yet again. What this means is a lot more local (US) support, new upgrades and accessories (custom rack shelves, keyboards, etc.). And yes a Contro4 IP driver is in the later stages!
post #193 of 377
Tried same MKV over NFS and USB, and getting judders in the same exact spots. Doesn't happen with Mede8er or Boxee Box. I'm stumped.
post #194 of 377
Try the M2TS.
post #195 of 377
I would expect it is either a hardware or fw issue, not network related.
post #196 of 377
Okay, figured it out... bad MKV. I demuxed it via MKVExtract, and remuxed it via MKVMerge, and perfect playback via USB and SMB. Also, tried M2TS, perfect playback. Bad news is I think I have many of these and I think the culprit may be MakeMKV. Started using it in Fall of 2011 for ease of use (had been using Clown_BD until then), and now I'll have to redo maybe 80-100 MKVs. Sucks, but at least uncovered the problem.
post #197 of 377
Exactly the reason why you should have stuck with clownbd + mkvmerge. I never hear of playback issues with mkvmerge but frequently enough with makemkv.
post #198 of 377
Clown_BD seems to make better files these days, lots of strange one off bugs with makemkv
post #199 of 377
Yeah, I'm done with MakeMKV... back to Clown_BD .
post #200 of 377
M2TS for perfect playback and best PQ every time.
post #201 of 377
Trust the dbone
I prefer just to stick with Blu-ray folder rips (I stopped using mkvs a while ago except for TV Shows)
post #202 of 377
I hear ya. I just like MKVs cuz they're single files, have low overhead, and support chapters.
post #203 of 377
MKV actually has more overhead. Takes more power to split the streams out of the format and send them to the decoders. But i agree im all for MKV's lol
post #204 of 377
I ordered an A-300, how long should it take to receive it? Will someone please recommend a 3TB hard drive to install? Thank you for your time
post #205 of 377
Are they still backordered and working from batches? If so, which batch is yours? If not, then what availability was listed when you ordered?
post #206 of 377
Curious to know if anyone has switched from a Netgear NTV 550 and found the PCH A300 superior and more stable ? I am hoping to get excellent BD ISO SUPPORT with BD full menu, don't stream only use an attached USB drive. Thanks.
post #207 of 377
You can use the PCH this way with no issues.
post #208 of 377
Unsure, don't know, no availabilty other than order comes from china on the website
post #209 of 377
http://networkedmediatank.com/forumdisplay.php?fid=115
post #210 of 377
So no signs of it being available on Amazon yet?
