Originally Posted by
ashope
evZap! is very easy to setup and run ... all of the eversion "eskins" are much easier than the old html-based skins.
cool will have to try some. I really like the stock skin as it gives you details without having to push down into each movie. Its really nice to get a summary without clicking to select the movie.
Hopefully some other skins retain this great feature.
Question: Can you automate the Popbox to boot into Eversion. With the C200 it would reboot back to the name network share see the index.html and auto load eversion so it "appeared" like eversion auto loaded.
is there any way to get this type of behavior or do I have to go apps then select yamj then select the quick start link. not exactly wife friendly.
I know the the 300 the same trick as the C200 should work but with the Popbox V8 there is no HTML skin support.
