I'm totally new to this so I can use some help. I'm considering wiring up my surround sound and put all of my tv components in a closet in a different room from the TV. I understand i'll then need to use an IR Repeater/Extender.
How do these typically work? Do you simply install a small IR eye, and then run that IR repeater back to the closet where the components all plug in?
How does the wiring work with a cable box, surround sound receiver, and blu-ray player?
