Originally Posted by
natemu06
It's use will be in radiology. I was hoping maybe they had some sort of security TV's or something. When CRT's were around they made specific radiology TV's with the knobs for brightness and contrast. Can't seem to find them anymore
Yes you can still find monitors with knobs and buttons on them to control contrast & brightness. They are used in professional studios. A standard LCD computer monitor will have brightness and contrast on it, without having to go through a menu.
In the case of using for radiology, check with the company that you use for your equipment, and they should be able to tell you best choice to use. Most doctor offices are using systems, that they can see the image through the computer network on the LCD screens at each workstation, that has access to the system.
