AVS › AVS Forum › Display Devices › Display Calibration › Advanced Portion of Service Menu Unlocked on Samsung LN32D550!
post #1 of 10
As the title suggests, I was able to access the advanced portion of the service menu on my Sept 2011 build Samsung LN32D550. It contains all kinds of picture settings including WB Movie and the ability to really turn dynamic contrast off, among various other picture items. I just selected advanced and pressed 0000 and then chose Picture_2D (after using the emulator trick).
post #2 of 10
Greetings
And this post has just made samsung change the code again for next year.
Regards
post #3 of 10
Does "DIY" really mean: "Destroy It Yourself?"
post #4 of 10
Originally Posted by Michael TLV View Post
Greetings
Regards
If you had actually bothered reading my post carefully, you'd notice the code wasn't ever changed. Instead they simply restored access to this portion of the service menu in the latest build on this TV (and possibly other new models as well). Furthermore, the most common service menu mistake newbies make is with the ADC Calibration menu, which was never hidden by Samsung despite the existence of 2-3 threads in this forum dedicated to the "Calibration Failure" issue.
post #5 of 10
Originally Posted by PlasmaPZ80U View Post
Exactly what have I destroyed? Your condescension on this forum knows no limits.
I was responding to Michael, not you. My intent could have been more clear. It was in jest, as Michael, and others who frequent this section of the forum, likely understood. Anyone familiar with the history of consumers dabbling in service menus can attest to the consequences some have encountered.
post #6 of 10
This has already been attempted on both the D550 and the D8000 and dynamic contrast could not be defeated. Using the debug menu available via serial link both janos and I set all of the Picture_2D enhance sub-menu items (BM_start, BM_start_max, BM_start_max2, Lfunc_gain, Hfunc_gain, LCE_Gain) to zero without effect. You can also turn off "Dynamic CE" and "Contrast Dimming" in the subsettings menu but all this does is disable the user menu Dynamic Contrast control.
post #7 of 10
Ok
post #8 of 10
Removing my offer after I sent it to someone and they complained it was too technical! Also I got 8 spam messages in one minute so now I know you really cant put out your e-mail address in forums!
post #9 of 10
Originally Posted by captaineos View Post
I have the service manual for this TV and it is NOT what you are expecting. It has one page that briefly explains what each thing means but doesn't exactly hold you hand.
E-mail me "jeremybh1@gmail.com
" and I'll send you the PDF
All TV service manuals are like this; they only make sense to those at the factory and (to an extent) the service techs who come to your home.
post #10 of 10
Can the service menus be used to turn off the automatic backlight dimming on this set? Or is there any way to turn them off? I bought this set to replace the previous model. I use the for technical purposes, and the backlight dimming is totally unacceptable. Thanks!
