AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Which CD Player should I keep which one should go?
post #1 of 7
I have an Onkyo DX-1400 and an older Teac Single Disc CD Player Model # PD-80. Which CD Player is better? Thank You for your help.
post #2 of 7
Lacking any other information, I'd say keep the one that's been used less. It'll probably last longer.
post #3 of 7
I am not able to provide Specs on these CD Players What other information do you guys need?
post #4 of 7
None. Specs would just tell you that they probably sound identical (which they probably do, if they're still in good working order). Hence my reply above.
post #5 of 7
None really. They are both very old models, if I were you I would keep both, so you will have a spare if the one you are using fails. Not like you could sell one for hundreds of dollars or anything.
post #6 of 7
Which ever one, after level matching the output, you prefer.
post #7 of 7
I still own my Onkyo DX-1400 that's in my office (not my main set up) & it's paired with a Nakamichi RE-10 receiver & some AR speakers. Anyway...The Onkyo still "chugs" along & it's still sounds very nice IMHO. It purchased that new back in 1990-91 I recall. Built like a tank!
