AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Got acer K330, how the hell can i get HDMI to work?
post #1 of 9
Anyone got this projector to work with his PS3 in HD? a simple yes/no would be nice, i have tried multiple cables and all it will never work in 720p or 1080p i can only get it to work on hdmi at 480p but the screen goes crazy (weird blur/artifacts/etc) when i connect the PS3 to any other LCD it works perfectly with no issue whatsoever
So have you played PS3 on HD 720p or 1080p on the ACER K330?
post #2 of 9
Switched off before change hdmi port?
post #3 of 9
Bad news? Sounds like a faulty hdmi connection on the unit. When I had the unit, everything worked ok. Whether the pj was on or not when I plugged in the hdmi cable, it worked fine regardless.
post #4 of 9
Update: i have replaced the projector a while ago but there is a new problem, the new one works with my pc but not with my ps3
post #5 of 9
One Faulty unit may acceptable but two? OMG! get another brand, LG PA70G with same resolution but has a 700 lumens, meaning you get more 200lumens than Acer K330. Please read the "LG PA70G LED 1280x800 700 Lumens" Thread.
post #6 of 9
What does the PS3 say when you select 720P as the resolution or is it not selectable?
post #7 of 9
Anyone get 1080p to work on ps3? Mine can only go 1080i if I remember correctly the first time i tried my ps3 1080p was working now that I tried again it can only go to 1080i. When I check the 1080p it will try to resynch and it says input not supported on the top right.
Edited by n1co35 - 9/4/12 at 7:21pm
post #8 of 9
Why are you trying to send a 1280 x 800 native projector 1080P? Send it 720P it will render better (Look Better) .
post #9 of 9
No problems with 720p sent to my K330 over an Xbox 360 on cheap 30ft ebay cable. I went one step further and disabled HDMI edid in the Xbox settings menu , then I told the Xbox to send 1280x780 always over HDMI.
I also have my one and only Xbox360 connected to a 4x HDMI Splitter , that splitter then send out 4 Identical signals to two 42" lcd's , one 32" led, and my baby K330. They all accept the 1280x780 signal and scale it better then the projector can ( read FullScreen ) My projector has 10 missing pixels on the top and bottom , but I like it better that way then 720p and missing 80pix.
Yes I can watch my Xbox on all 4 TV's at the same m*therf*ckin !! time cool.gif Legal Hack tongue.gif
