Originally Posted by Ken H
Ok. Bottom line on antennas:
Outdoors is better than indoors
Larger is better than smaller
Higher is (generally) better than lower
So if your are committed to getting an outdoor antenna, I'd be looking for one that was a large for the money as I could get, that was recommended by other members based on their experience. How much room do you have on the balcony?
What would others recommend in this situation?
Don't have a balcony,just a side porch with steps then a patio, front has the porch and then driveway which also connects to the patio on the side of the house
Originally Posted by arxaw
If you're getting dropped cell service and poor FM radio reception, you should not be at all surprised that you cannot get a TV station reliably at your location. Just because TVFool shows a station in a list of stations you may possibly receive, doesn't mean you will be able to.
There's probably tons of RF interference where you are. TVFool doesn't take that into account, because it has no way of knowing what interference is present at any given spot. Had you read the TVFool FAQ, you would know that there are many factors that come into play that sometimes make their predictive maps less than accurate. They even say, "Your Mileage May Vary."
Good luck with your shopping cloud antenna. I've heard those actually work sometimes.... until the plastic breaks and the antenna won't stay where it's aimed.
It doesn't drop the signal entirely or even calls, it just drops the 3G signal especially when I try to stream something or get a hold of the base of the phone. As for FM radio anything outside of the 100.x range doesn't come in without alot of static, there's also reception problems in the 105.x-106.x range. If RF interference was the issue what could I do about it?
no pine trees just regular trees in the direction of the towers as well as my neighbors garage and house.
I tried it indoors at the highest point in the house and still had these issues. Don't think it's the cabling as my cable service worked fine after Comcast put an amp on it in mid 2004 after some reception issues.
