It sure would be nice for us OTA enthusiasts to see the following:
1 Signal Strength Meter. If the set has an ATSC tuner, then a meter to see the strength of signal should be mandatory. I have never seen a cellphone without one so who is the dumb person responsible for this obvious fatal error? And the darn thing shouldn't be buried under multiple keystrokes like most are.
2 Favorite channel memory. Again, ATSC can be quite cumbersome to navigate with, and we need all the tools we can get. This particular "feature" has been around for a long time, so why would a set not have it?
3 EPG, Electronic program guides are very useful and to not take advantage of what is free runs contrary to my philosophy of what OTA is all about.
4 Tuner sensitivity, in microvolts, just like the good old days.
5 A smartly laid out remote is important and "quick scan" feature would really seperate the wheat from the chaff..
All the other specs are secondary in nature. You will be told whether it is 720p or 1080p. The contrast ratio, audio wattage, weight, and dimensions are helpful but we really should demand the first 3 items on this list as a bare minimum. What did I miss?
15-16 dB of usable signal, ABOVE the lowest point (dip) of the signal across the channel....the "dips" in the normally flat-topped haystack (as seen on a spectrum analyzer). Multi-path causes peaks and dips in that haystack.
