Originally Posted by kenglish
Can you tell us what markets/DMAs, and what stations are "overlapping"?
From rabbitears.com, we might be able to see if there is something the stations could do....I think that the "invisible" PSIP, like the Program Numbers, might be causing a conflict. The stations could, possibly, coordinate their PSIP numbering in those kinds of situations.
My Sharp Aquos tv tuner lists stations saved into memory by their Virtual channel numbers only, with manual entry possible only via Real channel number entry (which does manually add stations to the memorized station listing, but listed by Virtual channel number). It is able to save into memory multiple stations having different Real channel numbers but shared Virtual channel numbers, or overlapping Real and Virtual channel numbers, but only if they are saved into memory in a certain order. It cannot, however, tune two different stations that share Real channel numbers, so it will swap them back and forth with each other in the memorized station listing as they are received, or simply not ever receive the second station. My tuner has single scanning capability (but no additive channel scan that saves all stations from a previous scan).
Using a Channel Master 4228A on a rotor on my chimney (no amp), the overlapping stations I receive include the following categories:
1 – Shared Virtual channel numbers but different Real channel numbers, AND the Real and Virtual channel numbers are different from each other for each station – this is no problem, as tuning these stations manually by their Real channel number will cause my tuner to simply save both stations into memory as two stations listed one after the other under the same Virtual channel number:
WEYI (NBC) Saginaw, MI – Real 30.1 / Virtual 25.1
WVIZ (PBS) Cleveland, OH – Real 26.1 / Virtual 25.1
WNEM (CBS) Bay City, MI – Real 22.1 / Virtual 5.1
WEWS (ABC) Cleveland, OH – Real 15.1 / Virtual 5.1
2 – Shared Virtual channel numbers but different Real channel numbers, but one station’s Real channel number matches its Virtual channel number - my tv will save these into memory under their respective Virtual channel numbers, but ONLY if I enter them in manually by their Real channel number (or cause the first of the two to be auto-scanned in that way) in the order of the station having the SAME Real and Virtual channel numbers entered in FIRST. This will cause my tuner to simply save both stations into memory listed one after the other under the same Virtual channel number. But if I entered them in the reverse order (by first entering in the station whose Real and Virtual channel numbers are DIFFERENT), then attempted subsequent manual entry of the Real channel number for the other station will simply cause the tuner to jump to the Virtual channel number, tuning that same first station again, and never being able to enter or tune in the other station:
WVPX (ION) Akron, OH – Real 23.1 / Virtual 23.1
WUDT (Day) Detroit, MI – Real 8.1 / Virtual 23.1
3 – Overlapping, but crossed, Real and Virtual channel numbers – similar to #2 above, my tv will save these into memory under their respective Virtual channel numbers, but ONLY if I enter them in manually by their Real channel number (or cause the first of the two to be auto-scanned in that way) in the order of the station having the OVERLAPPING Real channel number entered in FIRST, and then the Real channel number of the other station second. This will cause my tuner to simply save both stations into memory listed one after the other under their respective Virtual channel numbers. But if I entered them in the reverse order (by first entering in the NON-OVERLAPPING Real channel number first), then attempted subsequent manual entry of the Real channel number for the other station will simply cause the tuner to jump to the Virtual channel number of the previously-tuned station again, and never being able to enter or tune in the other station:
WGTE (PBS) Toledo, OH – Real 29.1 / Virtual 30.1
4 – Shared Real channel numbers but different Virtual channel numbers AND neither station’s Real channel number matches its Virtual channel number – since my tv cannot tune two different stations that share real channel numbers, as I rotate the antenna for these stations, my tv will swap the two stations back and forth with each other in the memorized station listing as they are received (but can never store both stations into memory at the same time):
WDCQ (PBS) Bay City, MI – Real 15.1 / Virtual 19.1
5 - Shared Real channel numbers but different Virtual channel numbers AND one of the station’s Real channel number matches its Virtual channel number – since my tv cannot tune two different stations that share real channel numbers, once one of these stations is entered into memory (by any means), and I then rotate the antenna for the second station, manual entry of the same Real channel number again (looking for the second station) often causes my tv to apparently jump to the Virtual channel number of the first station, and continue to search for it (but the antenna is now aimed toward the second station), so I can never receive the second station without completely erasing the entire memorized station listing and starting over. But I have had at least one instance where the tv will add the second station right after the first one in memory (but it doesn't always do this; can't figure out why):
WSMH (FOX) Flint, MI – Real 16.1 / Virtual 66.1
CHWI (CTV2) Wheatley, ON – Real 16.1 / Virtual 16.1
CIII (Global) Stevenson, ON – Real 22.1 / Virtual 22.1
WCMZ (PBS) Flint, MI – Real 28.1 / Virtual 28.1
WUAB (MyNet) Cleveland, OH – Real 28.1 / Virtual 43.1
