This post was literally years in the making. After years of experimentation, I finally created the perfect audio system using used "garage sale" equipment. I experimented with every configuration possible, from speakers to AVR settings over the years. Now I can finally say, it's perfect.
My system is controlled by two AVR systems. Both have HDMI inputs and HDMI decoding. Both are 7.1 systems, but only six speakers are connected to one, and four to the other. I have them connected "daisy chain" style using HDMI. All components are connected to one unit via HDMI, which is connected to the second unit via HDMI, and the second unit to the TV. One unit controls all the front speakers (L, R, C, LH, RH, LFE). The second controls the surround and back speakers (SL, SR, BL, BR).
All my speakers, except for the rears and heights are large speakers. My surround speakers (large) has a frequency response that goes down to 35 Hz and a high of 20 kHz. My front speakers have a frequency response high of 25 kHz but a low of only 120 kHz. I have both fronts connected to an unpowered subwoofer I found that filters all audio from both channels from 120 Hz all the way down to 20 Hz. So, between the unpowered sub and the front speakers, I have a seamless combined frequency response out of my l/r channels of 20 Hz to 25 kHz.
My powered sub has a frequency response that goes down to 35 Hz. On the AVR, I have all speakers (except FL/FR) set as "small". The crossover frequency of the surround speakers is set to 40 Hz. The center channel speaker is a Polk Audio with a frequency response from under 80 Hz and up to 20 kHz. I have the crossover of the center speaker set for 80 Hz.
The front heights and rear surrounds are small speakers borrowed from HTIB sets. These do not have tweeters, unlike the other speakers in the system discussed above. The specs for these speakers say their frequency response is 80 Hz to 20 kHz, but my experimentation shows that I get the best sound out of them when the crossover for these speakers is set to 200 Hz.
THX recommends setting the crossover frequencies for large speakers to "small" and crossover at 80 Hz. I tried this for a while. I also tried setting the large speakers to "large". Trust me, setting them to "small" and the crossover just above the speakers' frequency response low makes a HUGE difference!
The exception to the above rule is if the speaker's frequency response goes as low as 20 Hz. Then, use these speakers as your l/r fronts and set the AVR to "large" for these speakers and the crossover to "full range" for those speakers.
If your AVR has "double bass" or "LFE + mains" as settings, DO NOT use these! If your center speaker sound sounds funny, experiment with the Dolby center speaker width setting. I have mine set for "2" and it sounds fine to me. A "3" setting makes the center sound boomy and a "1" setting makes it sound canny.
Set the AVR controlling your front and height speakers to Dolby Digital combined with Dolby Pro Logic IIz and the AVR controlling the surround and back speakers to Dolby Digital combined with Dolby Pro Logic IIx. Make sure the settings on both units are exactly the same or the sound will not be in sync.
Do not use any of the DSP formats or compression. Make sure you set the distance of all your speakers accurately. Make sure the front height speakers' are set three feet greater than the l/r speaker distance. The added three feet creates 3D sound.
Next, I plan on purchasing better quality speakers for the front heights and surround rears. I'm also thinking about buying a transducer for handling frequencies below 20 Hz. I'm also thinking of adding front wide l/r speakers later on.
