AVS › AVS Forum › Audio › DIY Speakers and Subs › JBL 5749 (2242 X 2) Re-config
post #1 of 14
My newly aquired sub was too wide to work where I needed it, so I rebuilt it to the same volume, just taller. I cut apart the 5749 cabinet to use the port and T nuts, etc. Now it should fit behind my AT screen and procenium. It will be powered by a QSC 4050HD.
post #2 of 14
Cool! I was wondering what you were going to do. Looking forward to what you think of them once you've mated them with your DTS-10.
post #3 of 14
Me too Scott! I also re-worked my equipment room to add the DCX and Peavy IPR3000. It will power the DTS and TD-18 (when it finally gets here).
I also swapped in an MRX300 instead of the Pio THX21.
I wish you lived close by so we could work the set up together.
Any progress on your project?
post #4 of 14
Yeah, me too. Most everyone around here is on the east coast or mid-west.
Yes! In fact, there has been a breakthrough wrt my mega mains. I've started work on the cabs and that's a sign that I should have them installed in the next month or two.
I can't wait to hear what you think of the JBL's and eventually a comparison of the JBL 18's versus the TD18.
post #5 of 14
Scott 's getting started soon. Yah!!
I have always heard some good things about the Anthem stuff. I still need to find myself a good AVR. But when spending $1400 on a simple Denon that only cost around 6-700 I just sucks I cant order one of these from the USA. I need to find a preamp that is has a universal PS under 1000 from the USA.
Then maybe I can build some of these Scott style monsters.
post #6 of 14
Set up a search on sleazepay for a step down isolation trans local to you. I picked up one a few months back for $2, rated 1kVA, full isolation (not autotransformer) and weighed 18kg so he wasn't going to ship. Preamps don't draw much power and even new a Tx shouldn't be that much.
post #7 of 14
Thanks. I have always seen cheap stuff in the USA but not here. But ordering stuff from the USA to work here makes things a lot cheaper.
post #8 of 14
Not always, check all your figures very closely and google around Oz sites for local prices especially for the bigger name stuff. I've been caught before and I used to trade instruments as a hobby, so lots of Oz experience importing and exporting. I was going to get my projector from the US, but the difference in price is minimal after some shopping around locally as an example. Not to mention warranty etc. Not always the case though.
Very few preamps offer much functional difference over an AVR, especially if you're using external amps, but preamps usually command a stiff premium.
post #9 of 14
Well...I realized I would have to do some re-construction behind the proscenium to fit the box, didn't realize just how much. The stage and proscenium weren't buit with 3 x 4622's in mind, much less 2 x 2242's and a DTS-10. Luckily for me, I had the 12" false wall where the previous IB was, so that made for another 1' of room. Like many, I started with "Hi-Fi" speakers...ha!
In the pics, you can see how I wrapped my 2384 horns with peel-n-seal. Can't hurt.
I also added the Mason Super W pads per THX, under each speaker. That's a pad on top of the speaker in the second pic.
http://www.hometheatershack.com/foru...screens-6.html
http://www.grainger.com/Grainger/MAS...tion-Pad-4C972
post #10 of 14
Any updates? I am loving my pair of 2242s.
post #11 of 14
Yes, it is all back together nicely. Mine aren't as purdy as yours, but they really are an amazing driver. The mid bass slam I have is over the top. I am awaiting my Mini-dsp to be able to properly intergrate them with the DTS-10.
I will then post some OM graphs.
post #12 of 14
Excellent! No reason to make them pretty when they are hidden behind the screen.
I tried War of the Worlds and The Lab scene from the movie Pulse. Wow, can these drivers move!! I was shocked actually.
What frequency did you tune the cabinet to? Have you tried comparing them to the DTS-10?
post #13 of 14
Nice!!
I have had my 2 for about 5 years. They are in 12 cu ft cabs tuned to 25hz.
Powered by 2 bridged HPA2's!! I really love mine!
post #14 of 14
I used the same volume as the 5749 (21 cu. ft. gross); taller instead of wider. I even used the actual port from the 5749 cab. It is tuned to 30 hz (+/- 3) http://www.jblproservice.com/pdf/The...eries/5749.pdf.
The DTS-10 definitely plays lower (which is no surprise), but the 2242's play with such visceral, chest pounding goodness. I have them running on different amps, so it's easy to compare. With the placement behind the screen I don't have the luxury of moving them.
My ultimate goal is to use the DTS from 15-50 and the 2242's from about (gotta measure to be sure) 35 up to the x-over. I also have to factor in my 6 x 2035's.
I'll also have another ported 18 (TD-18...if ever the GP ships) midway along the left wall in 12 cu. ft. I may just buy another 2242, they model nearly identical to the TD-18 anyway.
This should really smooth things out and require less amplifier, thus less distortion.
