So I have narrowed my search and wanted to check which is better.. JL Audio F112 vs Velodynes DD-12+.
This is mainly for movies for my HT. My intention is to get 2 subs, but I will get one first, check my frequency room response and if needed then get a second one.
I have a 3k cubic feet room where living rm, kitchen & dining area are combined. I do have an Integra DHC-80.3 that has Audyssey XT32.
My main goal is to have a good room frequency response. Although Velo seems to have a better EQ vs JL Audio... Not sure if it would make a difference since my pre-pro has Audyssey XT32.
Below are my pros & cons of each
Velo pros
JL Audio pros
JL Audio cons
I'm currently leaning towards JL Audio but I'm unable to find any comparison between these two.
Velo pros
- Recent upgrade from DD series
- Better EQ than JL
JL Audio pros
- Most dealers recommend JL over Velo
JL Audio cons
- A bit concerned that F112 is about 5-6years old. But again this may not be a con... If it's not broken why fix it ?
