AVS › AVS Forum › Audio › Receivers, Amps, and Processors › receiver Help!
receiver Help!
post #1 of 5
I am looking to but a new receiver, without spending much. I will either get a used, older high end or a newer low end receiver. I am looking to spend about 250-300. My question is: will the newer receivers have technology that the older ones don't have, like newer dolby developments. I am also wondering if the newer dolby developments sound better than traditional dolby digital. Also, is it smarter to but a older but expensive reliever (not too old, around the early 2000s) or a new receiver like this one:
I cant post urls but if you google yamaha receivers, go to shopping, the third one down
Thanks for looking, any help is appreciated.
post #2 of 5
Traditional Dolby Digital will sound the same.
If you have a Blu-ray player and want to take advantage of the Hi-rez Dolby and DTS formats you should look into a newer receiver. The audio differences/advantages differ depending upon the requirements and/or expectations of the individual.
OTOH, you may be able to find an older receiver that provides multichannel analog inputs. (Assuming you have a Blu-ray player with multichannel outputs)
post #3 of 5
Newer receivers almost always have newer technology. If you compared a receiver made now to one made six years ago, the older one lacks a lot of features that newer receivers have. Depends on what high end receiver you mean compared to what newer model(s).
Some stuff that's "newer" -
* HDMI
* Lossless audio
* Improved room correction systems/auto setup systems
* iPod connectivity, audio via USB memory, network audio etc.
* 7.1 (Not that new, but it depends on how far back you go)
* Dolby Pro Logic II/IIx (An improvement over Dolby Pro Logic)
There's a lot that's changed since DD receives first came out. For example, 7.1 came out later. As did lossless audio. 7.1 is probably a nice improvement if budget allows for the extra speakers, and your room allows for a proper 7.1 setup. Lossless audio is probably not important.
post #4 of 5
Thanks. I'll probibly Go with a used one that's only like 2 or 3 yo. My projector doesnt have hdmi so that's not an issue. You people seem to know a lot so I'll ask another question: my laptop has a bluray player but my current receiver doesn't have hdmi so I would run the Audio with a headphone to RCA cable. Would the audio be ok with that or should I buy a bluray player and run a red white RCA cable?
post #5 of 5
Dude you wouldn't even get more than two channels then! Does the projector have DVI? You do know it's the same thing as HDMI less audio right! I would assume if that notebook has Blu-ray it has HDMI out. You have potentially a great transport there then ehh! I'd make sure you get an AVR with HDMI input for sure!
Take a look at Denon AVR-1912 or AVR-1712. They can be had for around $300-500 from a good dealer on a deal...
