Guys I have some possible good news on future flat packs.
As many of you know, I've been getting them cut for a few different designs and boxing them up in my spare time. Also working to get different box sizes cut without driver cut-outs and of course, subwoofer kits.
Obviously it takes a couple days for me to get the packages boxed and shipped. But I've done pretty good so far.
My shipping rates are okay with FedEx, but probably no where near as good as Parts Express.
Because of that, I had an idea to contact PE to see if they wanted to handle some of the flat packs if I could get the boxes made up and delivered. I only live about 30 minutes away, so it seemed like a good idea. And I don't mind delivering them stacked on pallets because I go to PE every couple weeks anyway.
I talked to them today and they like the idea.
here's a few ideas I had.
8.5" x 14" x 12" (.5 cu ft) using 3/4" mdf is a must because there's a design coming for that size anyway.
8.5" x 20" x 12" (.75 cu ft) using 3/4" mdf.
1.25, 2, 3, 4, 5 cu ft, subwoofer with bracing will be priced.
What else would be good? I'm open for any size/shape ideas. Maybe a small satellite style flat pack? A stubby .75 cu ft box? Some smaller floor standers? Different subwoofer boxes? Any idea is good.
KITS Also!
Curt's Stentorians and his MTM's will likely be made up with his permission. I have to ask Paul C about more Overnight Sensations and if he's okay with PE carrying them. But I can continue with those myself if needed. Nano Neo's as well, but again, I will contact the designers to see what they think.
2 designs are coming out using the 6" Aurasound buy-out woofer in a .5 cu ft enclosure.
Of course, I'll still be helping with different kits that you guys want, so no worry about that. PE won't be carrying all of them anyway.
My shipping rates are okay with FedEx, but probably no where near as good as Parts Express.Because of that, I had an idea to contact PE to see if they wanted to handle some of the flat packs if I could get the boxes made up and delivered. I only live about 30 minutes away, so it seemed like a good idea. And I don't mind delivering them stacked on pallets because I go to PE every couple weeks anyway.
KITS Also!
That's when I decided to do the Anarchy tapped horn just to get things moving.
I was going to post this thread over on the PE forum first, then later in the week here!
