My desktop PC just died so I'm going to rebuild it with HTPC performance in mind. It will be my everyday PC not just HTPC and I will be doing video editing, ripping, Photoshop editing, word processing, etc. I plan to run a 50 foot HDMI cable from the PC to the HDTV set. IOW, this PC will be dual purpose. I don't play games.
I'm planning to use an ATX motherboard and although I'll be buying SATA hard drives, I already have some IDE data drives that I need to get data off of. An ATX motherboard that I found that has an IDE header on it is the ASUS P8H67-V. I'll be running video from the i5 but may buy an ATI Radeon 6450 card later if the i5's 24p repeat frames bother me.
So my build so far is:
- Motherboard: Asus P8H67-V (rev 3.0)
http://www.newegg.com/Product/Produc...82E16813131783
- Processor: Intel core i5-2500K
- Power supply: Antec Green EA380D, 380 watts continuous power.
- RAM: DDR3 1333, 8GB - which brand and model?
- Solid state drive: Any suggestions for a 64GB SSD?
RAM:
What about ECC? How do I know if my motherboard needs it or not? I don't see ECC listed in the details for the P8H67-V mobo. ----- Would this G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBNT be a good choice?
http://www.newegg.com/Product/Produc...82E16820231424
SSD:
Any suggestions for one about 64 GB in size?
Thanks for any help,
Sky
RAM:
SSD:
Sky
