AVS › AVS Forum › News Forum › Great Found Deals › A couple (smallish) Subwoofer Deals inside
post #1 of 3
Vanns has an extra $50 off (through 12/31) the Discontinued Boston VPS210. $349 shipped.
Amazon (via 6thAve) has the Klipsch SW-308 for $319 shipped. Sale might end at any time. Cheapest elsewhere online is just shy of $600.
post #2 of 3
Great little dual 8" passive drivers in each sw-308 sub (Klipsch is replacing the sw-308 with the new 15" active driven sw-115 sub in some of its Reference home theater setups) . . . Two things to consider at the awesome price: 1) the sw-308 does have the "WA" port to make it wireless with the Klipsch kit and move it anywhere in the room; and 2) at that price, you could have dual subs!
I have a Klipsch Reference 7.1 setup, but for a Martin-Logan sub I love . . . Without that ML sub, I would jump on two of these sw-308s at that price!
post #3 of 3
Thanks for the tip on the SW-308. My Klipsch RW-12d failed WAF. So I need a very small sub. Considered a Mirage MM8, but this one should do better for HT use.
  Back to Forum: Great Found Deals
