I want to connect an old desktop PC to my LCD/HDTV. The PC has a fair amount of RAM, etc., though I'm not certain on video connections.
Here's what I have...
HDTV- DVI-D Dual Link input
PC- VGA output
Questions...
1. Will I get the benefit of DVI-D Dual Link outputting from VGA with appropriate cable? Or, will I only get Single Link performance, regardless?
2. Does the converter (VGA-to-DVI) need to be the same as the cable and input? Meaning...I found a VGA/DVI converter in my A/V box but it has female DVI-I slots, though any DVI cable will fit into it. Will it properly convert VGA to DVI with the above configuration, or will I need to get a DVI-D Dual Link converter?
3. Does it matter where in the line a converter is placed? Such as...connect it to the VGA output, then the DVI cable, or connect it to the DVI input, then VGA cable? Does it matter?
4. Would I benefit, instead, by just getting a video card that has DVI-D Dual Link output, and appropriate cable?
-Scott
PC- VGA output
Questions...
-Scott
